M6 guys, what did 4.10's do to your track times?
Old May 26, 2004 | 09:59 PM
Mike94ZLT1's Avatar
I just swapped from 3.42's to 4.10's. Nice SOTP gain, what did you guys actually see?
Old May 26, 2004 | 10:03 PM
Flat_Tire_'s Avatar
Haven't swapped myself, however have talked to someone who has them .. He has a tough time getting traction at the track on street nights and he's running out of 4th gear by the end of the 1/4 .. he told me he's actually considering going to 3.73's.
Although I know if you can hookup, you can see really nice gains.
Old May 27, 2004 | 09:55 AM
GREGG 97Z's Avatar
.2-.3 and 2-3mph.
Old May 27, 2004 | 10:51 AM
rncotton's Avatar
.2 in the 1/4 mile and about 1.5 MPH gain in trap speed.
I'm on street tires, and a 1.9 60' time is as low as I can get them. Traction is hard to find with the 4.11 on street tires. But, trapping at 108.xx, I'm still in 4th gear, hitting 6K as I trip the light.
Old May 27, 2004 | 12:14 PM
redzsmoked212's Avatar
if your runing steet tires your gonna see mabye .2-.4 gains through on some dr's and youll get up to .6 gains.
Old May 27, 2004 | 10:12 PM
simple's Avatar
running out of 4th gear at the end of the 1/4?
never had that problem with 17" wheels and tires with the stock cam!
and i also found it easier to get traction :shrugs:
Old May 28, 2004 | 07:24 PM
Kevin97ss's Avatar
I think your the first person I've seen here say that! I feel the same way. After installing the Moser w/4.11's traction loss was much easier to control and it makes sence. True steeper gears increase torque which will make the tire easier to spin but it also reduces wheel speed @ a given RPM which = less momentum. If the tire loses traction it will take less time to get it under control.
Kevin
Feffman
Oct 9, 2015 05:42 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
Red97LT1
Aug 7, 2002 05:45 PM
