? about Vacuum pump and PCV system
Old Apr 4, 2004 | 03:25 PM
Mike94ZLT1's Avatar
Hey guys, I just installed my own catch can, and I'm also in the process of installing the vacuum pump found on TATOMMYWS6's website, www.tatommy.com Anyways, I do not have the same LS6 PCV system that he does, I have the stock LS1 system so I can not tap mine into the same place. I was wondering if its possible to connect it to a t-fitting I installed on the hose right before the PCV valve. I attached pictures of where I want it to go. Now the pump only goes at WOT, I am wondering if this will pull air from inside the intake being so close to it, or will the PCV valve stop it, and allow it to pull through the system like I want it to. Thanks!
Pictures can be found at http://ls1tech.com/forums/showthread.php?t=157111
HectorM52
Jul 30, 2017 11:46 AM
mmf_1013
Apr 11, 2015 11:03 PM
lt1matt
Mar 21, 2015 07:35 PM
mspennyhughes
Mar 1, 2015 03:50 PM
grgguy
17
Feb 23, 2015 07:57 PM
