Lt1
Old Apr 2, 2004 | 03:59 PM
PA91Z28's Avatar
Lt1
Hi everyone
I am new to the forum. I have a 1991 Z28 that is stock for the most part. Does anyone know when chevy started to put the LT1 engine in camaros. A friend of mine has a 86 Z28 with a LT1. From the info that I have found they did not use LT1's in 1986. So then I would think that someone put the LT1 engine in it later. I have had camaros before but am know just starting to find out more info on them. Thanks for any info.
Travis
Old Apr 2, 2004 | 04:35 PM
chevyman502bb's Avatar
LT1's started in 93, your friend did a swap
Old Apr 2, 2004 | 05:03 PM
Ville H. Valo's Avatar
and, in 1992 they put them in corvettes.
Old Apr 2, 2004 | 05:10 PM
FastWhiteTA's Avatar
I'd be skeptic about it being a complete LT1 engine. It's likely that he, or someone else, did the LT1 intake swap. but it is possilbe he has the whole LT1 engine. But they started in 1993 in the fbodies, and 92 in the Vettes.
Old Apr 2, 2004 | 06:02 PM
TheGreatJ's Avatar
Easy way to tell if it's a true LT1 or just an intake: look for the tell-tale distributor. If it has a distrib. in the back it's just an intake swap, or maybe intake and heads if they were really ambitious (that takes some welding on the heads.) If it's got an opti-spurt behind the water pump, it's a true LT1.
Old Apr 2, 2004 | 07:35 PM
Good point. Look for the opti spark on the front of the engine, or the lack there of distributor on the back of the engine.
Old Apr 3, 2004 | 05:24 PM
MY91Y84's Avatar
NOT always true....you CAN run an LT1 motor off a rear mount DIST, and have it FI...
Old Apr 3, 2004 | 05:47 PM
what does the stamp on the back of the block say?
EX : my Lg4 is stamped GM5.0LG whats the LT1 say? 5.7LT?
Old Apr 3, 2004 | 06:08 PM
Black6SpdTA's Avatar
I'd check the heads. I know of zero LT1 head'ed cars running. If it's got LT1 heads, 99.9% it's an LT1.
Old Apr 3, 2004 | 08:30 PM
TheGreatJ's Avatar
Yes, but then it's not really a "true" LT1. You'd have to modify the wiring harness, drill the intake, figure out the wiring etc. etc. You may even have to change ECMs so it will recognize the cam position signal from the distributor (instead of crank position from the opti.) It changes the whole nature of the beast.
Old Apr 3, 2004 | 09:18 PM
Dave89IROC's Avatar
um, guys? look at the water pump? if it is cam driven(it may be electric now), and both rad hoses go to it, it is a LT1
oldschool
Feb 9, 2016 09:21 PM
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
