OBDI basic tuning-setup Qs
Old Sep 16, 2002 | 01:16 AM
Dave 96TA's Avatar
Question OBDI basic tuning-setup Qs
So I have some questions before getting neck-deep in the sh*t that is custom DIY tuning...
1) I've got a 95 PCM ready to slip into my 96 - just to weigh my options, what resistor do I put where to make the OBDII knock sensor work correctly (instead of replacing the sensor itself).
2) Swap my LT4 KM into the 95 PCM or leave it stock?
3) How many times can the PCM be flashed before it becomes unstable? I'm quite familiar with electronics and specifically computer hardware, but I'm not sure what level of quality GM chose for this application. The reason I ask is because I may want to run 2 different programs (N/A and N2O) to maximize performance/engine longevity.
4) Tuning-specific question - IAC Target RPM vs. Coolant Temp (Park/Neu) (A.K.A. idle speed out of gear, for LT1_Edit folks - Idle Speed vs. Temp Deg. F)...does this affect the M6 cars at all?
thanks
Old Sep 16, 2002 | 09:40 AM
CanadianZ's Avatar
#3 If it's like any other flashable prom, it should be able to be flashed about 500,000 times or so. (Give or take a few)
CanadianZ
Old Sep 16, 2002 | 10:46 PM
Dave 96TA's Avatar
Thanks CanadianZ for the tip. Now I wont worry about running different programs safely.
Also, strike #1 from the list. I'm just gonna get a 95 knock sensor tomorrow from the dealership (or at least order it).
Any others?
David Dempsey
Mar 12, 2016 12:42 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 10:09 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
