Last bolt on transmission
Old Mar 23, 2004 | 07:13 PM
CamaroZ28LT1's Avatar
how do i get the very top bolt on the transmission in order to get to the flywheel?
Old Mar 23, 2004 | 08:18 PM
rskrause's Avatar
A "wobbler" like this http://content.sears.com/data/produc...4280000-mv.jpg and a long extension.
Rich Krause
Old Mar 23, 2004 | 11:29 PM
Klypto's Avatar
HEHE YEA! get a LONG extention.. i installed my clutch 2 weeks ago... had to get a 4-5 foot(literally) extention to get to it, was almost to the rear wheels! its nuts! but easy with the extendor... it jut took us 1 hr to realise this!
heh...
gl
cory
Old Mar 24, 2004 | 05:56 AM
rskrause's Avatar
Yeah, I should have said a LOOOOONG extension. Actually, I use a wobbler connecting two extensions with another wobbler on the "business" end.
Rich Krause
Old Mar 24, 2004 | 06:27 AM
Dan_gearhead's Avatar
I used 2 straight extensions (about 11") on my ratchet driver which I managed to fit, very tight but it did fit, between the tranny and floor, with the handle sticking out on the driver side if you get the picture....I also managed to bend my left arm around the tranny on the same side so I could feel the socket sitting right on the bolt...
Old Mar 24, 2004 | 07:50 AM
riceinmybowl's Avatar
top one on the bell housing? if you mean that one, i let the tail hang down on the trany unsupported then layed on top of my motor with a wrench and got it form there. just have the car up high when you do it so you got room to get your arms in.
Old Mar 24, 2004 | 10:56 AM
ok i got one bolt from somewhere im guessing that wasnt the one becasue my tranny is still conected, whatever bolt it was it was attached to a black thing like a piece of plastic so how far up am i talking? thanks for the help guys
Old Mar 24, 2004 | 11:38 AM
Camaro97USAF's Avatar
was it attached to a bracket that held some line on top of the tranny? If so that was one of the bolts.... And yeah as everyone already said... looong extensions. I think I had 7 ft of em at one time because I was getting pissed and just screwin off.
Old Mar 25, 2004 | 08:20 AM
ok all of the bolts are out but now i cant get the tranny to slide back, my friend and i used screw drivers to try to pry it apart but nothing, if anything it only prys out one side at a time but very little so i know all the bolts are out, we jacked it up tried almost everything, so i was just wondering if there was something i might of forgot to do after removing the bolts, any hints, sorry i'm just afraid of messing things up so i ask alot of questions to i know im doing it right but thanks for all the help.
Old Mar 25, 2004 | 08:35 AM
Have you pulled the clutch arm out?
Found a write up that might be of help:
http://zachz28.8m.com/z28/tutorials/clutch/clutch.htm
Old Mar 25, 2004 | 12:24 PM
Klypto's Avatar
did you pull the tranny before tryign to get the bell housing off first?
Old Mar 25, 2004 | 01:24 PM
ok i tired pulling and prying the tranny out without even touching the clutch fork, you dont think i hurt or bent it ???? but now i will take the clutch cylinder off then remove the clutch fork out, plus i need to know im installing a used clutch do i need to shim it??? im not getting my flywheel resurfaced or anything. so how do i get my shift point down?
Victor Lamb
Aug 26, 2017 02:52 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
maybe2fast
Mar 16, 2015 09:45 AM
jackpawt883
Feb 26, 2015 09:04 PM
thenewkid
Nov 27, 2014 09:41 AM
