Evacuation Pumps
Old Mar 14, 2004 | 08:19 PM
jdaly's Avatar
Evacuation Pumps
I need the paperwork for a Aerospace Components 4-vane Pump for a dry sump system. I baught the kit used but have no information on it.
Old Mar 15, 2004 | 09:00 PM
OldSStroker's Avatar
You might start here:
http://www.aerospacecomponents.com/vacp.htm#vp
This probably isn't the right place to post this type of question.
Try this:
http://web.camaross.com/forums/showt...threadid=47092
Old Mar 18, 2004 | 02:32 AM
MaxRaceSoftware's Avatar
http://www.maxracesoftware.com/BBC_Vac_Pump_4.jpg
i'd always purchase the 4-vane pump , then you can tailor vacuum amount easier to what you want
sometimes 3-vane is not enough
the larger CID of engine
the higher the compression ratio
the worse the rod ratio
the worse the hone job/ring seal
the more the vauum pump will gain Torque and HorsePower
HectorM52
Jul 30, 2017 11:46 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
4586
Apr 24, 2015 01:03 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
