Carb to FI swap- i dont think anything else could go wrong! help///////1
Old Sep 2, 2002 | 04:43 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Post Carb to FI swap- i dont think anything else could go wrong! help///////1
ok, tpi is on the 73 vette and
it gets hot as hell under the hood
coolant gusge doesn;t work but the lines are realy ****ing hot!
we thought the RR were making the loud noise but its only on one side- thinkin knock?
and then all at once lots of smoke comes out of the PCV and sidepipes
our o2 sensor reading is 0.02x
anyone hav any idea whats up?
more than one problem?
the "rr" noise was there before teh carb swap
it also idles irratically
thanks!
Old Sep 2, 2002 | 08:14 PM
RedIrocZ-28's Avatar
Trey, I have the same problem. #1 Make sure that there are NO vacuum leaks. #2 Get a 3 or 4 wire O2 sensor. The factory style 1 wire hasn't worked for me on my new motor at all so I am gonna switch. Also, make sure that the TPS sensor is reading .54V with the throttle blades closed and also that the IAC is functioning correctly. In my opinion the IAC and O2 are probably at fault. Get a temp guage on that damn car too! Overheating=blown head gaskets/cracked heads.
Old Sep 3, 2002 | 12:35 PM
treyZ28's Avatar
we also have no knock sensor...
Old Sep 3, 2002 | 08:31 PM
97 RedSS's Avatar
Thats just not smart on a new engine..Coolant temp guage needs to be hooked up..
Cody
97 30th Anniv Camaro SS#2374~ Forged 383 w/4 bolt mains,Pro5.0,LT4KM,Pro Performance Heads(288in/216ex@.600"),GTP-6 cam,Comp. Magnum 1.6" RR's,Chromoley Pushrods,Edelbrock Double Roller,MeziereWP,52MM BBK TB,Hooker LT's w/ Custom 3" Y-pipe,Borla,SLP CAI,30# Inj.,OBD1PCM,SPEC Stage 3 Carbon
Old Setup Dyno #'s on Stock Bottem-End NA~ 370rwhp/353rwtq
My SS
E.T.F.A East Texas F-Body Assoc.
-Kiss my SS-
Old Sep 3, 2002 | 08:36 PM
treyZ28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 97 RedSS:
Cody
</font>
hmm... intresting
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
Kawi
Sep 28, 2015 09:01 AM
Aaront810
Sep 11, 2015 11:24 AM
