Compression test results....let me know what you think...
Old Sep 3, 2002 | 12:38 PM
ElkyRacer's Avatar
Post Compression test results....let me know what you think...
Well, I got around to running a compression check yesterday to see if I had beat the seats into the heads by floating the valves. Here are the numbers....
1-160
2-160
3-165
4-160
5-160
6-170
7-160
8-Couldnt get the gauge in that cyl with Longtubes
Seems like thats pretty good numbers wouldnt you say? Thats with a 10 to 1 comp motor with a 230/236 110lsa cam. Im thinkin everything is hunky dory, so Im going to put a set of springs on it and see how it does. Anyone see any problems with those numbers? I know the 170 reading is a bit higher than the others, but it was dark, and I might have not been reading the gauge correctly.
Kyle aka Shaggy
Purple 95 Formula
ETFA
12.00@116
Old Sep 3, 2002 | 01:27 PM
kmook's Avatar
Advanced Tech Moderator
Kyle, Those numbers look fine to me.
I will move this to LT1 Tech though, thanks
KYWes
Jun 14, 2022 06:52 AM
Quickss96
Jan 29, 2016 05:56 PM
cmsmith
Sep 14, 2015 09:25 PM
karpetcm
Aug 14, 2015 03:02 PM
13qtr
Jul 19, 2015 05:30 PM
