Spun bearings, is block still good?
Old Jul 16, 2002 | 04:45 PM
95LT1Z28's Avatar
Post Spun bearings, is block still good?
My buddy has a 95 LT1 block that we just disassembled and noticed he spun 3 main bearings on the caps. Is the block still usable and can it be machined? The stock crank also suffered some damage from the spun bearings, but can the crank be machined also? I don't know a thing about how bad or not spun bearings are so please forgive my ignorance. Thanks!
Jeff
95 Red A4, 3.73
MAC headers/y-pipe (PBM coated), Magnecor wires, AC Delco Rapidfire #3's, Borla cat-back, K&N FIPK, 160 thermo, PCMforless programming, B&M shift improver, TB Airfoil,!TB, 17" SS rims, 275/40ZR 17 Kumho's, Eibach Pro-kit, Bilstein shocks, Hotchkis STB, BMR SFC's, BMR LCA's, BMR PHR, BMR front 32mm and rear 21mm sway bars, 1LE Driveshaft
Old Jul 16, 2002 | 11:41 PM
Stephen 87 IROC's Avatar
The crank will depend on how bad it's been damaged. Only your machinist will be able to tell you if it's salvagable.
The block "may" be saved. The mains will need to be line honed and resized. I guess it's going to depend on the bearing retainer groove. If it's wiped out then it's probably not salvagable. Possibly only main caps are required but then it will still need to be line honed.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
