Cam Heads and Springs Question
Old Jul 16, 2002 | 09:51 PM
BadnBlkSS's Avatar
Post Cam Heads and Springs Question
Will a 620 lift cam fit with a set of aftermarket heads that flow 300X280. I was going to combine them with a set of 1.6 roller rockers. I need a little help with what type of springs I should get for the set up. The cam is coming new from a friend and is comp cams so I am still getting more info on it. I want to tranfer the complete heads to a motor with a supercharger on it. Will these get the job done on this motor as well? Thanks for the help in advance
Old Jul 16, 2002 | 10:53 PM
kmook's Avatar
Advanced Tech Moderator
First off please give more info on your application. What car/engine/components/amount of boost your going with/your goals etc. It is pretty impossible to give answers without knowing the whole picture.
Second, are you sure on those head specs, they seem a little off.
Lastly this is not an advance question, i would move it to the proper forum exept i dont know where to move it since you didnt say what engine your working with...
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Catmaigne
Dec 25, 2014 12:16 PM
smokin5s
Jul 24, 2003 10:47 PM
