Wheel/Tire Question Inside...
Old Mar 7, 2004 | 10:51 AM
WickedZ's Avatar
Exclamation Wheel/Tire Question Inside...
Hey guys,
I'm buying new wheels and tires, going with Weld's Draglite XP 16x8.5" Rims.
My question is, will ET Streets of this size fit without modification on my '95 Z28: 26x11.5x16?
If not, what do I need to do, and thanx in advance!
Old Mar 7, 2004 | 02:56 PM
97bowtie's Avatar
They'll fit fine.
Old Mar 7, 2004 | 07:48 PM
rskrause's Avatar
Why 16"? 15" tires will launch harder.
Rich Krause
Old Mar 7, 2004 | 10:31 PM
z28kid93's Avatar
11.74 @ 114mph on a 1.56 60ft....
Bolt on LS1, 4400 stall, on that SAME rear rim combo. Seems to hook pretty good to me I still prefer the 15" rim, but these were cheap at the time.
Old Mar 8, 2004 | 06:10 AM
TRICK95's Avatar
Rich Krause
Sorry, this is my work account, but I want the 16" because I was told you have to modify your brake calipers to run Weld's 15" rims. Is this true? Hell, if not, I'll just go skinny/fat combo and be done with it.
Old Mar 8, 2004 | 07:03 AM
rskrause's Avatar
You can get some longer studs and use a spacer. Otherwise you will need to grind the calipers to use 15" wheels.
Rich
Old Mar 8, 2004 | 07:31 AM
z28kid93's Avatar
could always go with the Centerline Convo Pros. They didn't need any caliper grinding in front or back if i remember correctly. I know for sure that the fronts fit without any grinding on my '98Z
Old Mar 8, 2004 | 10:50 AM
Serene's Avatar
Spacers on the drive wheels cutting 1.5 60' times? No thanks.
Old Mar 8, 2004 | 10:56 AM
rskrause's Avatar
They have been used safely for years. If properly designed, constructed, and used it's no problem.
Rich Krause
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
