Timing / Knock retard
Old Mar 6, 2004 | 12:02 PM
Jeremy_30th's Avatar
what is normal ? at idle i'm showing up to 23deg of timing and knock stays below 1deg but while driving its went as far as 2 or 3 deg... and timing while driving up to 40 deg..please help is this ok ?
Old Mar 6, 2004 | 12:35 PM
Hal Fisher's Avatar
ARe you at high altitude? I ask because someone else on the board was seeing almost constent kr at anything over .4 map and it might be due to his high altitude location (over 5000').
Hal
Old Mar 6, 2004 | 12:41 PM
yes i belive its over 5k the local track is abt 6k I think
Old Mar 6, 2004 | 01:30 PM
Hal Fisher's Avatar
I wonder what could be done to compensate? Maybe setting an AFPR higher (wonder what it reads now), or adjusting down the timing in all fields. Maybe find someone at the pits with a similar setup who scans and alters their pcm and ask what they do to correct?
Hal
HectorM52
Jul 30, 2017 11:46 AM
mikey4play
Mar 15, 2015 11:45 AM
jayblev95
Dec 1, 2014 06:55 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
