Advancing or retarding timing...
Old Sep 8, 2002 | 08:58 PM
96z's Avatar
96z
Post Advancing or retarding timing...
Can someone give me a quick lesson on this topic...Im trying to find tune my car right, ie. idle and I need a few pointers, warnings etc. before I go about it.
Thanks
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
Old Sep 11, 2002 | 09:10 AM
96z's Avatar
96z
Noone knows?
Old Sep 14, 2002 | 07:31 PM
96z's Avatar
96z
Someone please!
Old Sep 15, 2002 | 06:38 PM
gb95zconv's Avatar
I moved my timing from 20* to 27* at idle to smooth it out a bit. Also did the same for low rpm low map to help with surg. As always save a copy of your file before you modifiy it.
Old Sep 16, 2002 | 12:06 AM
Hal Fisher's Avatar
If the idle is too loopy increase the rpm a little to smooth it out.
Hal
Old Sep 16, 2002 | 12:11 AM
96z's Avatar
96z
But is there a general rule that advancing timing will increase HP will retarding timing will decrease it?
What determines how much timing you need?
Old Sep 16, 2002 | 09:23 AM
red's Avatar
red
Head design (porting), cam profile, fuel, altitude, CR, etc will determine the total advance your motor will like. Will some general info on these items people can make recomendations but you will only know for sure by making changes and testing the results.
nosliw
Mar 9, 2016 04:56 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
