Problems with ECU
Old Jul 21, 2002 | 09:54 PM
sleeperz28's Avatar
Post Problems with ECU
There is a constant 12volts going to the ecu. When the ignition is on is there not another wire that signals the ecu to turn the fuel pump on, ready to engage the starter, etc...
Well my computer no longer receives this signal. If anyone has time can they check the black connection number 30 on the ecu connector. I believe this wire should read 12volts with the key on.
Or if you have any other suggestions, car no longer starts primes the fuel pump or engagest the starting seliniod.
Old Jul 22, 2002 | 05:38 AM
There are two +12V connections to the PCM.... one from the battery (PCM BAT) and one from the ignition switch (PCM IGN). Both have fuses. What year is your car? LT1? They are not all exactly the same. Fuse locations differ from year to year.
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
May 25, 2016 08:10 PM
Klypto
Mar 23, 2016 09:05 AM
Mar 13, 2016 03:39 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
