South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Good brake Shop?
Old Feb 23, 2004 | 07:16 AM
gol10dr's Avatar
Good brake Shop?
Ok guys, As you read in another post.. I swapped my rear for a disk brake rear. Something just doesn't seem right with the brakes. Does anyone know a good brake place I can take the car so they could look at it and maybe figure out what's wrong. Hopefully they won't freak I don't have a emergency brake cable... or a cat convertor. Thanks.
Old Feb 23, 2004 | 11:25 AM
gol10dr's Avatar
ttt
Old Feb 23, 2004 | 12:21 PM
darkoverlift's Avatar
bump....
Maybe more details on what you think is wrong might help.
Old Feb 23, 2004 | 12:30 PM
MustangEater82's Avatar
I am telling you bleed the suckers...
I blead them like 10 times... seemed like no air was in them but there ended up being some Others had the same problems...
car just seems like it doesn't stop fast enough right?
What I used was a lawnmower fuel line(sold at autozone) its just a clear tube, put it over the bleed nipple on the brakes, and used and empty gataorade bottle, just go back and forth back and forth with the brakes, you more then likely just have air in the line.
Or are you having other problems?
Old Feb 23, 2004 | 12:32 PM
Grinds, squeaks, moans... I do not think he has the right rotors still..... Something is odd with the setup.
94 rear, 97 calipers, 96 brake pads.... 97 Disc's so go figure...
Old Feb 23, 2004 | 12:43 PM
All that stuff should be compatible...
Are the rotors and pads new?
I went like 4 months on the junkyard pads and rotors I had...
Old Feb 23, 2004 | 12:47 PM
Here is what I know:
With new pads rotors do not fit. So John Grinds down the pads on my bench grinder and you can now slide the rotors on, but still snug.
Stange lines form pads occuring in rotors could be due to non flat grinding.
Pads do not seem to come back and forth fast enough IMO.
Old Feb 23, 2004 | 01:04 PM
Try opening the brake fluid resovoir... then using a push the piston back in slowly. to make more room.
Old Feb 23, 2004 | 01:06 PM
We are talking off with no lines the pads seemed to big... Or was it the wrong rotors.
Old Feb 23, 2004 | 01:17 PM
these are pics of front pads but this is the difference in thickness...
one is worn to bare metal other is a new hawk pad.
http://www.mustangeater825.50megs.co...of%20pads1.jpg
http://www.mustangeater825.50megs.co...of%20pads2.jpg
the rears were the same difference.(yes that is Vin diesle looking over my shoulder )
and for laughs I found the pic I showed my mom to explain to her where I broke my torque arm, I think she made fun of me for a week for the pic.
http://www.mustangeater825.50megs.co.../location1.jpg
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
