vortec tpi cam recomendations
Old Feb 15, 2004 | 07:58 PM
slow_roc's Avatar
im building a 350 (40 over ) roller, with vortec heads (2.02 1.60) ,Scoggin Dickey tpi base, accel runners, 52mm tb, 24lb injectors, and im wondering wht would be a good cam to get around 400hp and hit 12s (currently have lt1 cam but dont think that will give me more then 300hp ) wondering what you guys have or would recomend
thanx steve
Old Feb 15, 2004 | 11:39 PM
stanghunter211's Avatar
Yeah I am curious too. Contemplating the same thing here. What made you decide to go with a 52mm TB? I really don't see the point. You could spend that 300 and buy a cam. Larger TB's are not gonna help us out unless we are making some MAJOR hp. Just to put it into perspective for you. The RamJet 502 makes 502hp and 502 #/ft of torque and uses a 48mm TB. In some cases , size really doesn't matter
Will
Old Feb 16, 2004 | 12:22 AM
aklim's Avatar
I thought the larger TB gives better throttle response but not power? Someone correct me if I an wrong.
Old Feb 16, 2004 | 12:24 AM
I guess some might get an improved throttle response, but I doubt that has anything to do with size. More so the fact that it is a new unit as opposed to our 12 year old or older TPI TB's.
Will
Old Feb 16, 2004 | 12:28 AM
aklim's Avatar
I would think you need to know what is the max lift supported by your heads and springs and also if it would crash the piston into the valve.
Old Feb 16, 2004 | 12:34 AM
Scoggin sells 3 different phases of the vortec heads, each capable of taking more andmore lift. Here is a link totheir site that will give you an idea of what to look for.
http://sdpc2000.com/cart.asp?action=...art&catid=2172
Will
Old Feb 16, 2004 | 06:21 AM
slow_roc's Avatar
yeh with the throttle body i had my old one bored (under 200) so i figure it would help some for that price and my heads currently have a 510 lift spring in them so i could always go bring (they have already been machined) but i was jsut wondering what cam some people have had some luck with and what kind of results
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
dansam
Jul 20, 2002 01:10 PM
