Cam info requested....Which one, which one??
Old Jan 22, 2004 | 01:44 AM
globalco's Avatar
Post Cam info requested....Which one, which one??
With Vortec heads, siamesed runners and a vortec manifold I am looking for the best cam. Also running a trick 700R4.
My mechanic says the GM ZZ4 is a good streetable cam. I personally like the LT4 Hotcam as a healthy alternative except for the necessary computer reprogramming. I will be using the car 98% on the street and love to wind on the freeways.
Can anyone help with alternatives? Comp Cams, Crane, Edelbrock, Isky, Lunati, ASR, etc.
Jim
Old Jan 22, 2004 | 07:32 AM
Sitting Bull's Avatar
Need way more info.
What size engine? Rear gears? Roller or flat tappet?
Old Jan 22, 2004 | 03:54 PM
Rice Killer87's Avatar
i wouldnt use the LT4 hot cam b/c from what i hear the power band for that cam comes in as the TPI comes close to runnin outta breath. if it was me,i would just call Comp Cams and talk to their tech line and see what they recommend.
Old Jan 22, 2004 | 04:38 PM
globalco's Avatar
response
350 ci, SLP headers, Siamesed runners, Bigmouth base, stock gears for a 1992 Z28 and trick 700R4.
I am going to install the cam along with Vortec heads and manifold. I plan to port and match the heads, manifold and runners as well as open the runners and plenium a bit.
All this is in a 92' Z28
Jim
Old Jan 22, 2004 | 04:39 PM
globalco's Avatar
Rockers
Stock 1.5 roller rockers.
Old Jan 23, 2004 | 02:13 AM
OK, unless you modify the spring seats and use different springs, the Vortec heads aren't safe for a cam with more than about .460 lift.
Thus my best advice is to call either Comp or Crane on their toll free 1-800 line and tell them exactly what you have. They'll nail the right cam for you, so DO take their advice.
Good luck and let us know what they recommend
rideordie
Nov 5, 2019 04:52 PM
chuyz28
Jan 15, 2015 04:14 PM
bernie1951
Dec 10, 2014 10:03 AM
Queens94z28
Nov 20, 2014 06:03 PM
Elcojoe
Nov 17, 2014 10:27 PM
