RSKrause Going from low lift 224xe cam to high lift? any real gain?
If im doing the head swap... Is it any real gain going from the low lift version of the cam to the high lift one that you have?
More or less how much? and where can I get that cam?
Thanks
Thanks
Re: RSKrause Going from low lift 224xe cam to high lift? any real gain?
Thanks
Thanks
Rich Krause
I thought it was going to be more of a difference.. the other question is: will the 116lsa help my idle better? and also widen the mid range??? It has a lot more lift at .200" so... there should be more of a difference...
Once I get my heads flowed I will post them here to let you know.
Rich Krause
Jan 23, 2015 01:13 PM
