Low/High Impedance Injectors
Old Jan 14, 2004 | 10:47 PM
ablackcamaro's Avatar
I've been looking at DFI sites and everything I see is about low/high impedance injector controls. Whats the main difference, is it gonna be something w/ reaction timing? And also what's stock on the LT1? Thanks, Rob
Old Jan 14, 2004 | 10:58 PM
LiT1_up's Avatar
Injectors bigger than 50 lb/hr are low-impedance. The PCM will not run low impedance injectors.
Old Jan 15, 2004 | 07:28 AM
rskrause's Avatar
True, unless you use the Acceleronics "low impedance converter". A great piece.
Low impedance converters draw more current, and the stock PCM injectors drivers can't handle that much heat.
Rich Krause
Old Jan 15, 2004 | 05:52 PM
arnie's Avatar
Another thing, the LI 'peak and hold' injector has a faster open/close response time. This allows the use of larger injectors to be programed to a lower pulse ms rate. This is helpful to get a cleaner idle cuppled with the larger capacity injector.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
