4gauge wire or no 4gauge wire....
Old Jan 6, 2004 | 02:48 AM
PredatorZ28's Avatar
i have two 12w3's and a jl500/1 amp ... should i run 4gauge or is the 10gauge i have now ok?
Old Jan 6, 2004 | 03:36 AM
PaulN64's Avatar
4awg
Old Jan 6, 2004 | 12:32 PM
skmoore21's Avatar
Umm, 4AWG, most definately!!!
Old Jan 6, 2004 | 10:35 PM
it is worth it? i will notice a difference is sound?
Old Jan 7, 2004 | 06:42 AM
97FormulaWS-6's Avatar
No difference in sound, but you may prevent your car from burning to the ground by pulling too much current through a 10 Ga wire....
To give you an idea, I'm using 10 Ga Speaker wire on my subs, I NEVER, NEVER, NEVER use anything smaller than 8 Ga for an amp, and that's only a small amp, or the very short run from the Distribution Block to the amp (typically less than 3')
Old Jan 8, 2004 | 04:50 AM
Tair's Avatar
Definitely run the 4awg wire! Unfortunately you will not notice a difference in SPL. The 10awg you are using now is OKAY, but if you run the amp hard enough you'll surely blow a fuse. 4awg is expensive, however, if you ever want to run a distribution block to another amp, it'll save you quite a bit of trouble. btw PredatorZ28, I sent you a PM about my remote start alarm throwing an SES light. Please read the message I sent you, I need help!!
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
