Torque Specs for Eagle Rods???
Old Dec 22, 2003 | 12:10 AM
TwEaKeDSS's Avatar
My eagle 6in h-beam rods came with ARP bolts and I don't know where to find the torque specs for them? Anyone know
Old Dec 22, 2003 | 12:29 AM
GhostZ's Avatar
This is all I could find bish.
http://web.camaross.com/forums/showt...ue+specs+eagle
Oh...and this:
http://www.bfranker.badz28.com/fbody/torquespecs.htm
Old Dec 22, 2003 | 04:04 AM
rskrause's Avatar
Re: Torque Specs for Eagle Rods???
ARP's web site has 'em, I believe.
Rich Krause
Old Dec 22, 2003 | 12:11 PM
TwEaKeDSS's Avatar
Called Eagle this morning, 63ft lbs with ARP lube
Old Dec 22, 2003 | 01:19 PM
sleeperz28's Avatar
If you have the 8740 bolt, the stretch is .063", and recommended torque is 60ft. However, when I assembled mine it took 72ft lbs to get them to stretch to the desired.
What im saying is get yourself a rod bolt stretch gauge thats the most accurate.
Old Dec 22, 2003 | 06:30 PM
OldSStroker's Avatar
Oops, that's .0063 bolt stretch, right?
Bolt stretch IS the most accurate way to get the correct clamping load.
Old Dec 22, 2003 | 07:41 PM
TwEaKeDSS's Avatar
I called Eagle and they said with the H-Beam rod #CRS6000B3D it comes with the ARP 7/16" capscrew bolts 190,000psi and the torque specs are 63ft lbs with arp lube
Old Dec 23, 2003 | 12:02 PM
sleeperz28's Avatar
Yeah, yeah forgot a 0 that could have been a terrible thing
Yes eagle claims this torque spec, but bolts dont always stretch proparly so thats why I use the gauge. however if you use the arp lube when torquing the bolts a majority of the time the bolts will stretch proparly.
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
rje
Sep 9, 2002 12:35 PM
