alum. head lt1---biggest valve
Old Dec 22, 2003 | 11:53 AM
BIGCOWL-IMP's Avatar
whats the biggest valve you put in these heads
i have seen 2.02 in alum. and i have seen 2.055 in the irion lt1 heads.???
Old Dec 22, 2003 | 01:12 PM
sleeperz28's Avatar
The valves on mine are 2.080 on the intake, 1.60 on exhaust. The afr 227's come with 2.100 on the intake, 1.6 exhaust
Old Dec 22, 2003 | 01:29 PM
KCFormula's Avatar
IMHO if you are going to rev very high I would not go over 2.02/1.60s. When high reving engines dont have enough material between the valves that material can crack.
Old Dec 22, 2003 | 08:52 PM
SSlammedlt-4's Avatar
I have 2.05/ 1.60 on my alum z heads.
Old Dec 23, 2003 | 02:22 AM
bunker's Avatar
AFR227's have 2.08 & 1.6 just like my AFR220's that are laying somewhere in my room, screw them, I'm using LT1 heads for my NA setup maybe save these for my turbo setup, & the 383 laying around is for turbo aswell, sucks to be broke & have no job, but its awesome to have santa around
Old Dec 23, 2003 | 12:06 PM
sleeperz28's Avatar
Better check again, they have the valve size on there site I believe. Because of the bigger valve the intake valve is offset requiring custom pistons for the valve reliefs
Old Dec 23, 2003 | 12:54 PM
SStrokerAce's Avatar
I was going to say that.
With a bigger valve seat you can get a 2.08 valve in the LT1 heads.
Bret
Old Dec 23, 2003 | 11:53 PM
jimlab's Avatar
2.10"/1.625" in AFR 215cc RRs...
http://home.gci.net/~jimlab/images/H...d/P1020025.jpg
Old Dec 24, 2003 | 03:51 AM
bunker's Avatar
Hmm. mine are 2.08's I even measured them, they are AFR220's, I have a motor they aren't going in has 31CC dished SRP pistons, so that shouldn't be a problme for valve reliefs
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
