6sp tranny swap
Old Dec 12, 2003 | 09:20 PM
okon's Avatar
Cool 6sp tranny swap
Hi Everyone,
I have a 67 camaro that currently has a LT1 & 4L60E from a 96 Z28 & a 95 cpu. I want to replace the 4L60E with a 6sp tranny. I would like to know what I am about to get myself into. I know there will be some mods. Can anyone tell what I will need for this conversion and possible problems or mods? I expect some mods with the clutch setup and maybe the mount, cpu & driveshaft. My camaro was originally a manual but was converted to auto by a previous owner.
Also, would this be a worth the effort???
Thanks....
Old Dec 13, 2003 | 10:56 AM
camcojb's Avatar
I'm assuming you're speaking of using the LT1 style T56? In that case there's a couple of nice kits to bolt the trans in without drilling a single hole. ATS makes a nice kit that uses the factory F-body (LT1) pull-off clutch and flywheel. If you want to run a standard earlier style clutch then Weir Products makes a nice kit that comes with a new bellhousing. I've installed both and they both fit perfectly. That gets the trans in; the driveshaft will have to be re-done. The other issue will be with the factory CPU; I do not know the specifics of that part, but am positive a company like Ron Francis can re-wire whatever is necessary.
Jody
Cam's maro
Aug 11, 2015 07:45 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Boss002
Jul 24, 2015 10:47 AM
