$$ required for turbo project
Old Nov 23, 2003 | 09:33 PM
94z6410's Avatar
I am beginning to explore turbo for my 94 z28. could someone please detail everything i will need for a turbo system and approx how much its gonna cost me.
Also, how much boost could i safely run on a stock z28?
Also, what are some methods of lowering compression?
Old Nov 23, 2003 | 09:54 PM
engineermike's Avatar
http://www.proturbokits.com/gmkits.htm
Old Nov 23, 2003 | 10:34 PM
Highlander's Avatar
There is the TT kit from chargedair also
Old Nov 24, 2003 | 08:21 AM
mongse_1's Avatar
If you’re thinking about DIY, then it all comes down to how much work you can do yourself. My twin setup will cost less than half of what CAS wants for their twin kit because 90% of the work is being done by myself.
If you want to get a pre-made kit, PTK would be my suggestion.
Old Nov 24, 2003 | 03:39 PM
LT1RX7's Avatar
I did every single thing myself on my project and here are the prices I've come up with
exhaust manifolds- $250
exhaust piping- $300
wasetgate- $300
turbo- $600
injectors 42#- $300
BOV- $100
FMIC- $420
intercooler piping- $100
oil lines- $60
Here are some things that you're gonna want to change as well
cam- $280
lifters- $250
rockers- $200
pushrods- $50
clutch- $500
LT1 Edit or other fuel ****- $300+
So far that is what I have come up with. I'm sure I'm missing something though.
BTW, stay away from FMUs if possible. Buying bigger injectors is the way to go. Raising the fuel pressure can lead to hot spots in the cylinder which can cause detonation.
Here's a pic of my setup so far
http://www.torquecentral.com/attachm...achmentid=4667
Old Nov 24, 2003 | 04:06 PM
Camaro37's Avatar
LT1RX7, isn't a FMU necessary unless you go DFI since the stock PCM cannot adjust for boost?
Old Nov 24, 2003 | 04:22 PM
LT1RX7's Avatar
FMU is not required if you get bigger injectors and program the computer with an LT1edit. FMU is a simple cheap fix. If funds are available stay away from FMU. 94z6410 sounds like he's running a stock block so he's only going to want to run around 6psi. Depending on what ratio FMU is installed fuel pressure can go over 100psi. Shooting 100psi of fuel through an injector that was only meant to flow 40psi is asking for trouble.
Old Nov 24, 2003 | 04:30 PM
got_hp?'s Avatar
thats a work of art!
Old Nov 25, 2003 | 05:11 AM
magius231's Avatar
well, since noone else did it...
http://www.ststurbo.com
right now the kits are on sale for $2999 with the turbo, which is way cheaper than any other kit out there aside from a DIY. People have been pulling some awesome numbers out of them too.
LeftoverChinese
Jan 14, 2024 03:03 PM
surreybrad
Apr 22, 2015 06:40 AM
cmdeshon
Dec 12, 2014 10:51 PM
Wilson
Jul 21, 2002 05:08 PM
