228/228 Lunati question
Old Nov 17, 2003 | 07:58 PM
93Cam's Avatar
Recently i've been looking a lot at cams because my stcok 3.4 just isn't doing it for me. So, my question is, would the lunati 228/228 cam be too aggresive for my daily driven beast, or should i go for a more mild cam. If so, what would you guys recomend. Thanks for any input.
Steve
Old Nov 17, 2003 | 09:27 PM
kmook's Avatar
Advanced Tech Moderator
Hey Steve,
I dont have any personal input on a cam for you as i've never really done much on the v6 side...
But general cam discussion/recomendations should be discussed in a generation spacific forum. Transfering- Thanks.
Old Nov 17, 2003 | 10:21 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
is that dur , or adv dur?
Old Nov 18, 2003 | 02:16 AM
oil pan 4's Avatar
how much lift does it make?
Old Nov 18, 2003 | 11:29 AM
93Cam's Avatar
duration is 228/228 at .050, lift is .465 with 1.5 rockers, lobe seperation angle is 110, and intake centerline is 106. It is a hydraulic flat tappet cam.
Old Nov 19, 2003 | 08:53 PM
93Cam's Avatar
30 views and two people talk.
Old Nov 20, 2003 | 06:14 AM
oil pan 4's Avatar
That is to much lift for stock springs You will need some new springs.
For $42 YOu can get Kmotion K-700 valve springs from summit and fhose are good for .5'' of lift.
Old Nov 20, 2003 | 10:52 AM
atl2001's Avatar
it wont be the best on the street, any aftermarket cam will be worse on the street over the stock one, but it should be driveable still, but yes it should be rough
Old Nov 21, 2003 | 09:47 PM
93Cam's Avatar
thanks a bunch guys, so what is a good cam that wouldnt be outrageously rough or bad on gas?
Old Nov 22, 2003 | 03:43 AM
oil pan 4's Avatar
crane cams 2-272-H
216*/228*
.454''/.480'' with 1.5 rockers or .480''/.511'' with 1.6's
Red_94Formula
Jan 22, 2015 12:17 AM
SpeedJunkee
Jan 14, 2015 05:34 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
BIGCOWL-IMP
Sep 12, 2002 09:18 AM
BIGCOWL-IMP
Jul 22, 2002 04:28 PM
