Changed spark plugs
Old Nov 3, 2003 | 02:21 PM
OutlawLS!'s Avatar
Changed spark plugs
Yesterday I decided to take on this gloriious task. Oh man, did this suck.
My buddy helped me and we took about close to 3 1/2 hours(joking around in between). Drivers side went pretty smoothly. We had a hell of a time with the passanger side. Plug #8 was a b!tch to get out. But it finally got . Had to get under the car for that one.
Glad to say car runs alot smoother and better. I useed NGK's. I'm just glad I don't have to change these every year.
Old Nov 3, 2003 | 02:28 PM
z28sspeedracer's Avatar
I was thinking about changing the spark plugs on my car but after looking at the tight spaces I cahnged my mind. What tools did you use etc?
Old Nov 3, 2003 | 02:44 PM
OutlawLS!'s Avatar
Thumbs up
Here man. I use this webpage for reference. It helped me out and also let u know what primary tools you need.
The only other tool I need not mentioned there was a SWIVEL ADAPTER for the ratchet. You're going to need at least once. Just be sure not to mess up the gaskets for the air tubes, if not you will need those too.
http://www.installuniversity.com/
Old Nov 3, 2003 | 04:47 PM
cool thanks.
Old Nov 3, 2003 | 08:15 PM
2002Z28SSConv's Avatar
I just removed the passenger side coil packs when I did my friend's '99 Hawk spark plugs. You'll still need the swivel though. I think you can get by without it. But it makes it a lot easier.
Old Nov 3, 2003 | 08:43 PM
SpecForceZ28's Avatar
I got by without the swivel
Old Jan 19, 2004 | 10:17 AM
Craft's Avatar
Just changed my plugs and wires on Saturday and OMG!! My right hand looked like it was run over by a car when I was done!! Used Install Unverisities guide... Awesome work guys!! I didn't need the swivel either...
Old Jan 19, 2004 | 07:21 PM
Schantin's Avatar
Re: Changed spark plugs
You think an LS1 is bad....try an LT1! It took 2 DAYS to change the plugs/wires on my old 97 Z28. The wires route along the front of the block under the pulleys and belts. The 3.8 V6 is just as evil. That requires a collection of mirrors, swivels, and a lift as ALL the plugs on that one come from the bottom, but all the wires are from the top. (I've had the joy of owning both for tune-ups.)
It is a rough job.....but I bet you felt good after doing it yourself. NGK's were a good choice too.
Schantin
2002 Camaro Z28 M6
Old Jan 19, 2004 | 08:50 PM
Ferocity02's Avatar
If you remove the coil packs it is a very easy job to do, just need a ratchet and a small extension. Even the #8 cylinder was a breeze. I did this during the cam swap so can't tell you how long it took exactly. Getting the old ones out and the new ones in took 10-15 minutes, I even torqued most of the down to proper specs.
Old Jan 20, 2004 | 09:38 AM
z28chrizz's Avatar
I found the number 8 was easiest to get to from under the car... laying down, feet pointing towards the rear of the car... took a lot less time than the other plugs on the pass side. Also took off that EGR apparatus on the pass side and made things about 10 times easier. Took me 4 hours to do it, and this was with quite a few breaks and distractions... the usual when you are in the shop with 4-5 of your buddies.
I changed my stock plugs at 24k... and they were shot. Burned, gaps ranging all over the place, and miserable in general. Swapped to Bosch platinum+4's, best mod yet... car runs a lot better and maybe even a little harder To anyone who thinks the stock plugs are good to 100k because the owners manual says so... not by a longshot. Sure they will fire at 100k, but not like they should...
Took about 4 hours to do the 4 on the drivers side on my buddies LT1 with LT headers... havent even attempted the pass side
Old Jan 20, 2004 | 04:40 PM
hrtbeat2's Avatar
My first time it took me 2 1/2 hrs, so thats not to bad, but I'm runing NGK I believe tr55 but I gap them @ .55 They came @.6 I'm runing a cam and Lt and Computer tunning and so on whats everyone else gapping sorry to steal your thread.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
