Banjo Bolt size
Old Oct 26, 2003 | 01:26 AM
wishingforls1's Avatar
Banjo Bolt size
HI, New to the board. I have been trying upgrade my 97 Grand Prix brakes to 98+ f-body calipers w/ 12' Intrigue rotors on the front . Being my first brake job I have ever done, the back took a couple days...broke a couple rachets, 7 years of rust built up on everything. well to get to the point, I am going on roughly 9 days of not having a car. I stripped my first caliper, so i ordered a new one wich took 3 bus. days to come in. now I get the new one and i lightly strip the new one. This is when i find out i need a diff. banjo bolt. Well no one has a listing for it and the dealerships dont stock them. This is getting kind of excessive, figuring i have to drive to work mon - fri. and have been relying on rides the past week. I have the part number and i did a search. Does anyone know the size, i know its fine thread, but I need deminsions so I can pick it out of a misc. banjo bolt bin at pep boys.
Old Oct 26, 2003 | 10:48 AM
If I understand your question correctly, you have 98 F-Body calipers, and need to know the banjo bolt size/threads. You would be more likely to find the answer among 98-02 owners, most of whom will be found on "LS1 Tech". Moving thread there....
Old Apr 14, 2004 | 04:20 PM
SMOKNZ's Avatar
Just went thru this looking for a LS1 brake banjo bolt, and the size is M10 x 1.0. Figured I'd add this to this old thread for someone who may need the info and looks it up in the archives!
Bill
Old Feb 19, 2005 | 05:07 PM
pillagenburn's Avatar
Angry Re: Banjo Bolt size
wtf is the brake banjo bolt? where can i get a banjo bolt? i need one
Old Feb 19, 2005 | 08:10 PM
SMOKNZ's Avatar
Re: Banjo Bolt size
You don't know what one is, but you need one
Its a bolt with a hole in the center, and some side holes. It attaches the brake hose to the caliper, and allows a 90 deg connection which fluid flows thru the bolt.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
