High Idle??
Old Oct 23, 2003 | 01:30 PM
shwine617's Avatar
High Idle??
My car idles kinda high then it smooths out to a low idle sometimes, it started doing it after i changed the injectors, i was going to play with the idle screw on the throttle body, but i read that you shouldn't move it. any help would be great , thanks
Old Oct 23, 2003 | 04:20 PM
Z28James's Avatar
My car would idle at 1500 RPMS...well still does since my carb is screwed....its because of a really bad vacuum leak.
Old Oct 23, 2003 | 04:46 PM
aklim's Avatar
What size injectors and what else have you done?
Old Oct 23, 2003 | 04:50 PM
shwine617's Avatar
everything done to my car is written below, i have 24 lb injectors.
Old Oct 23, 2003 | 11:13 PM
aklim's Avatar
Sounds to me like you need to redo your EPROM because it is set for 22 pph injectors not 24.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
