Pass Key Ii......
Old Sep 28, 2003 | 01:09 PM
I EAT T/A's Avatar
Question Pass Key Ii......
My '91Z obviously had PASS KEY II and my '87 didn't. Am I going to be able start my car if I just lose the control module for PASS or will I end up having to swap more crap off the steering column???
Old Sep 28, 2003 | 01:45 PM
Dave89IROC's Avatar
to eliminate the PASS key (also known as VATS), you need to bypass the starter enable relay(easy, cross 3 wires) and delete it from the prom(in the ECM-computer)
there are other ways(resistor in wires to column, painless wiring delete box, ect.,), but this is the most complete
Old Sep 29, 2003 | 11:35 AM
I EAT T/A's Avatar
What if I'm not using the steering column from the '91??? Or is the starter enable relay in the fuse box?
Formula Steve
Sep 19, 2023 08:31 AM
KYWes
Sep 26, 2015 08:49 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
Aaront810
Sep 11, 2015 11:24 AM
jackpawt883
Sep 10, 2015 08:53 PM
