Here's what I have, what else to retard?
Old Aug 10, 2002 | 03:14 PM
JamesN1830's Avatar
Post Here's what I have, what else to retard?
I have a MSD 6A ignition box. I always thought there was a modual of some sort that could control timming? What do I need to retard timming?
James
95 Z28 M6
-355 forged 11:1 motor and Nitrous Works Wet kit 125 shot
Old Aug 11, 2002 | 07:18 AM
MichiganSkip's Avatar
James, Do you have a way of logging runs? I log 0* ignition retard off the juice and upwards of 10 degrees on the juice. The PCM retards the timing all on it's own on my car. Try logging runs w/o and on the bottle to see what is going on. You may not need to buy any retard device.
Skip
Michigan Skip's Flamed 95
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
Old Aug 11, 2002 | 09:18 AM
JamesN1830's Avatar
I'm a 11:1 forged motor that is fresh. I don't want to take the chance. If a modual or something is ~$80 or so, then it is worth the insurance to me. I need this motor to last somewhat of a long time.
James
95 Z28 M6
Old Aug 13, 2002 | 07:19 AM
RunRiot's Avatar
MSD adjustable timing retard is ~$100 from Summit Racing. It hooks up to your MSD ignition. Retard 0-15 degrees by turning a ****.
Old Aug 13, 2002 | 09:43 AM
Tofus 93Z28's Avatar
Lightbulb
part number 8982 from summit is what i use...works with all 6 series msd ignitions..it is a single stage setup, it ties into the nitrous circuit, when it see 12 volts on the circuit it pulls timing...it has plug modules varying from 0 degrees and up...im using a 4 degree pill with my 150 shot... for safety sake i should be using a 6 degree pill , but on my scanner the 4 degree pill seems to be doing the job....
DO NOT let the OEM computer handle the timing control on nitrous... this is a disaster waiting to happen...0 knock is what you want to see even on the juice....
Old Aug 13, 2002 | 11:27 AM
JamesN1830's Avatar
I know not to let the cpu handle the timming job. I want to be safe and effective on this one. Anyone use summit part number msd-8680?
http://store.summitracing.com/partdetail.asp?part=721
James
95 Z28 M6
asilomar244
Jul 12, 2015 05:53 AM
jdelaprida
Jul 4, 2015 03:02 AM
jdelaprida
Jun 27, 2015 08:30 PM
Fred94LT1
Aug 26, 2002 12:15 AM
tbyrne
Aug 16, 2002 01:12 PM
