How many rwhp is a 255 intank pump good to?
Old Aug 4, 2002 | 02:35 AM
Speeds8erM-1's Avatar
Post How many rwhp is a 255 intank pump good to?
How many rwhp is a 255 intank pump good to before you need to add an inline pump? Will one handle close to 600 rwhp?
1980 Camaro Z28 Sikkens 3 Stage Blue and Purple
1994 Camaro Z28 Teal M6
Ported Heads, LT4 Hot Cam and Springs, 1.6 RR's, Mac Headers and Offroad Y Pipe, Flowmaster Catback, Resonators, Flowtech Cutout, NX 150 Horsepower Shot of Nitrous, NX Bottle Heater, NX Remote Bottle Opener, NOS Purge, KB DD SFCs, BMR STB, Hypertech 160 Thermostat, Redline Water Wetter and Synthetic Diff. Fluid, McLeod Dual Performance Clutch, K&N FIPK, LT4 KM, 1LE Bellow, Holley 58mm Throttle Body, TB Coolant Bypass, Metco Valve Cover Breather, LPW Rearend Support Cover, Strange 3.73s, Eaton Posi, TA Stud Kit, Lakewood LCAs and Adjustable Panhard Rod, LS1 Driveshaft, March Underdrive Pullies, MSD 6AL, MSD Window Switch, MSD Blaster Coil, NGK TR6's, Mobil 1 Synthetic, Pro 5.0 Shifter, Intrax Lowering Springs, BFGoodRich Comp TAs 255/50/16, Nitto Drag Radials 245/50/16, AVS Blackouts on the back.
339 RWHP Corrected with two broke rings
465 RWHP Corrected on the nitrous with the clutch slipping bad and two broke rings
www.geocities.com/speeds8erm1
Old Aug 4, 2002 | 05:10 AM
rskrause's Avatar
Not all "255lph" pumps are equivalent. My current setup is good for 733rwhp. Bosch 255lph intank, Kenne Bell "Boost-a-Pump", stock lines and regulator.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Aug 4, 2002 | 01:54 PM
Derrick Redd's Avatar
I'm running almost 126 mph traps with a Holley/Walbro 255lph fuel pump. No problems with fuel.
<A HREF="http://personal.msy.bellsouth.net/msy/k/r/kraest/derrick.htm" TARGET=_blank>1994 Z28 A4
LT1 Motorsports equipped stock-bottom end LT1, LT1 heads, Hydraulic-Roller Cam, Dope
11.03 @ 125.53 1.61 60ft.
7.08 @ 99.05 1/8 mile</A>
1984 Mustang L
92' 5.0 roller motor, T5, NOS plate kit, etc.
14.03 @ 100.51 2.29 60ft. NA on street tires
Dope with slicks ????
Old Aug 4, 2002 | 03:49 PM
I have a Granatelli 255 Intank Pump thats stock pressure. I hope thats enough or actually well more than enough.
Old Aug 4, 2002 | 08:02 PM
bowtiepwr's Avatar
&gt;Does anyone have the dual intank 255LPH (GSS-340m) setup from Agostino-Racing or Racetronix ? I am sending in (brand new) sending unit to get modified for this . I was quoted the price of $500.00 for the plug and play for the LT1 . Does this sound reasonible ?
Later ...
stay safe
God Bless the United States Air Force ... !!!
1994 Z28 with some goodies
2000 Silverado LS Z71 ext cab
Old Aug 4, 2002 | 08:34 PM
Thats supposed to be a nice setup but $500 is alot conisering a 255 Intank Pump is about $120 and you are getting two with that setup and the stuff to make it work.
Old Aug 9, 2002 | 05:18 PM
Racetronix's Avatar
Lightbulb
<font face="Verdana, Arial" size="2">Originally posted by Speeds8erM-1:
Thats supposed to be a nice setup but $500 is alot conisering a 255 Intank Pump is about $120 and you are getting two with that setup and the stuff to make it work. </font>
At $500.00 its a bargain considering the amount of labor and parts that goes into making a PnP double pump setup and the complexity of the PnP weatherproof harness.
Go to your local dealer and see what it costs to buy a Weatherpack relay, socket and the sealed connectors. You can spend your money on an simple DIY install kit like the Racetronix unit or you can pay a shop $100's of dollars in labor to install an external pump with all the fittings and lines and electrical. Its your choice...
FYI a Racetronix double in-tank system has supported over 800RWHP to date with volume to spare!
http://www.racetronix.com/images/Fue...ble_Pump-4.jpg
Jack
Racetronix
Racetronix
sales@racetronix.com
Old Aug 9, 2002 | 08:41 PM
George Debski's Avatar
If any of you guys believe that a 255lph pump puts out that volume at the fuel rail and 43psi, I've got some bridges to sell you
SSMOKEM
1995 Impala SS "Cherry Bomb"
Best ETs: faster than my '65 pickup
Mods: 93% stock
My Super Impala SS Website
HectorM52
Jun 23, 2016 08:42 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Skull Leader
Aug 10, 2002 11:01 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
