Windows squeek when I roll them down.
Old Feb 19, 2002 | 01:40 AM
Jibberish18's Avatar
Post Windows squeek when I roll them down.
It sucks! Imagine rollin up on some chicks and rolling down your window and "SQUEAK!!". Embarassing and annoying. Why does this happen? I'm guessing it's because of the seals that stop water and such from rolling down into the window wells? They look like they don't work anymore. And when I try and clean them they're so dirty that no matter how many towels I use it's still dirty from 12 years. Any ideas guys and gals?
1990 Mercury Sable 3.0
Front Strut Tower Brace
Subframe Connectors
Old Feb 19, 2002 | 08:54 PM
kruzmsl's Avatar
Your on the right track. Just clean he heck out of them.
Bright Red 1997 Camaro
3800 series II V6
5 speed
Kenwood CD player
12 inch Crossfire DB subs
Q-forms enclosure
Kenwood 921 amplifier
Codealarm security
Tinted windows
front and rear blackouts
Motorola handsfree kit
Dynomax cat back dual exhaust with chrome outlets
MOFBA Board Moderator
www.mofba.net
Old Feb 21, 2002 | 08:58 AM
TechCam97's Avatar
Smile
Dang man, that's 12 year old weather-stripping. No wonder it's making that squeak. If cleaning it won't stop it, then just buy some new weather-stripping from AutoZone or something.
- Matt
White 97 Camaro V6 Conv. / Black 96 Camaro Z28 M5
160 Therm, Air box cut-out, plugs, BMR Strut-tower brace (To the 6)
"The only way to increase a mustang's value is to fill it with gas."
Old Feb 21, 2002 | 09:49 AM
Death's.Stalker's Avatar
just replace the trim man..it's not very expensive.. you also may wanna grease all the gearing in the door.. but first used wd4 to break up all the caked on crapp .. also check if the rod for the door locks isnt resting against the glass.
check and see if the window alignment padts aren't warn out either.. they are just below the windo trim.
If it aint broke...I get first dibbs..
don't sweat the petty stuff & dont pet the sweaty stuff
Blue
less lagg same stuff
Old Feb 21, 2002 | 01:14 PM
Well I don't mind replacing them but they don't exactly look like they're parts to pop in and out. I hope you guys know exactly what part I'm talking about. I don't know the exact names for them. It's usually the rears that squeek.
I know they're not exactly functioning correctly because let's say you have fog on your window. and you put your window down to eliminate it right? Well when I put my down and roll it back up I have patches in the window meaning their was no contact being made. Does this make sense?
Subframe Connectors
Old Feb 24, 2002 | 10:26 PM
TTT. Sorry If I'm getting annoying.
Subframe Connectors
Old Aug 8, 2002 | 07:15 PM
wilbs600's Avatar
dont worry you aren't just lube them up good
Old Aug 8, 2002 | 08:41 PM
ImportKILLER's Avatar
Yup...thats embarassing. I don't know whats worse...the squeeking window or rollin up on some chicks in a 1990 Mercury.
-Nathan
1996 Camaro
3.8L Series II, SLP CAI, Catco cat, Taylor 8mm wires, LSD, 3.42 gears, Borla catback.
1995 Dodge Stealth R/T
Twin Turbo Intercooled 3.0L AWD M6,A'PEXi AVC-R boost control, HKS Blow-off valve, K&N FIPK, Denso Iridium plugs, 245/40/18 Kumho Supra, Borla Catback, Mobil 1 fluids.
*VVvvTTttFFff* TNC since 1981!
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
