Coolant Temp Sensor
Old Sep 11, 2002 | 10:20 AM
Smooothie119's Avatar
Question Coolant Temp Sensor
where is the coolant temp sensor located on TPI engines, is it one of the harnesses near the TB? And what are some syptoms of a faulty sensor?
Old Sep 11, 2002 | 11:06 AM
84406's Avatar
It would depend on exactly what the failed position of the sensor was but most probably it would be no or low temp. From that you would get higher richer idle, richer while cruising and the fan won't come on when the car gets hot. It is one of the two sensors just below the TB.
The temp gauge is powered from a different sensor so what you see on the gauge is not what the ecm sees.
Bob
Old Sep 11, 2002 | 03:41 PM
Drkhrse89's Avatar
Another symptom of a fail CTS is your fans will not work. I just had this happen to me a few months back. It is located right under the TB on the right side. VERY easy to change out.
Sorry just reread the previous post and he covered what I just said. Sorry about a "double" post.
[This message has been edited by Drkhrse89 (edited September 11, 2002).]
95_Z28/SS
May 20, 2015 01:23 PM
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
