No/Low Oil Pressure ?/
Old Sep 7, 2002 | 05:21 PM
user 647483's Avatar
Post No/Low Oil Pressure ?/
I have a 1992 305 TBI Firebird with about 117k on it.
I honestly can't say that I have paid much attention
to my oil pressure guage as of late. But I noticed that
my check engine light is on today and the pressure is
reading 0 at idle and still in the red while accelerating.
I know it was fine last weekend (the last time I remember
checking)
I thought it might be related to the new chip I put in so I swapped
back to stock ... no help.
Any suggestions?
I'm going to change the oil and filter tomorrow anyhow, I hope
it's just a clogged filter or something equally stupid.
James D Montigny
1992 Pontiac Firebird 305 TBI
Bone Stock Officer, I Swear !
The members of this board are enthusiasts, not experts.
Please consider everything that you read an opinion.
Old Sep 7, 2002 | 07:58 PM
aklim's Avatar
AFAIK, the chip has no effect on the oil pressrure. If you engine is making a racket then you have low pressure. If not, I would ground out the sensor and see if it goes to the max pressure. If it does, it is probably a bad sender. If not, probably a bad gauge.
Old Sep 7, 2002 | 08:41 PM
It's just a coinsidence that it happened after installing it I guess LOL. But still.
James D Montigny
Old Sep 7, 2002 | 08:58 PM
TheGreatJ's Avatar
Cool
Probably is a coincidence...I know that I replaced 2 oil pressure senders in my 91 TBI 305 before I swapped it out for the 355. They kept blowing the diaphragm out and leaking oil through the sender...very annoying when you're cruising along at 80 and suddenly realize you're reading no oil pressure.
TheGreatJ
1991 Camaro RS "Suzanne"
http://thegreatj.cz28.com
Old Sep 7, 2002 | 09:10 PM
aklim's Avatar
<font face="Verdana, Arial" size="2">Originally posted by James Montigny:
</font>
Maybe you noticed it at the time you did the install. I checked the wiring diagram and can find no link.
What error code did you have? It should be stored in the ECM
Old Sep 8, 2002 | 02:53 PM
DOH Code 51 .. think I put it in backwards and fried the chip .. dangit
James D Montigny
Old Sep 8, 2002 | 11:26 PM
aklim's Avatar
Where did you get this chip? You can't put it in wrong because there are nubs on the edge which will not allow you to insert it in the wrong way unless you mash it in. Your prom may be faulty or just plain wrong. I have got those from ASM many years ago where they worked but triggered a code which might be 51. Not sure. After that, I went to Lingenfelter's and they did a true custom prom for me. Another place that is just as good is www.fasterproms.com and they do a true custom chip. Burn to your specs and have you take readings and reburn till it is just perfect. Takes about 3 burns to be just in. Cost is $500 for the first chip and later on if you make major mods and need a reburn, it is $150
Old Sep 8, 2002 | 11:41 PM
Actually, it's a 92 305 and you can put it in backwards. The little plastic case you put the chip into accepts it either way.
James D Montigny
Old Sep 9, 2002 | 08:22 AM
aklim's Avatar
Hmmm. My 91 accepts it only 1 way. What happened when you reversed it?
Old Sep 9, 2002 | 06:58 PM
When I put it in with the notch (Pin 1) facing the (1) and large notch on the platic carrier (facing the middle of the ECM) the Check Engine light flashes rapidly and the car runs like crap.
When I turn it around, the car runs a little better but the check engine light stays on solid and throws a code 51. (Bad PROM)
I need to figure out which way is the right way before I install a new chip.
James D Montigny
[This message has been edited by James Montigny (edited September 09, 2002).]
Old Sep 10, 2002 | 01:33 AM
aklim's Avatar
I think this is the wrong chip for the car. Where did you get it?
Old Sep 10, 2002 | 07:26 AM
<font face="Verdana, Arial" size="2">Originally posted by aklim:
I think this is the wrong chip for the car. Where did you get it?</font>
It was in a 91 Camaro 305 TBI Auto. I'm going to try my stock chip and see if I can make it work
James D Montigny
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
