S-Trim Questions
Old Aug 21, 2003 | 12:30 PM
RealQuick's Avatar
S-Trim Questions
Hey guys, me again. Incase you dont know me, I just purchased a Vortech V1 S-Trim. I am looking at the parts and it has an FMU, Teal colored MSD Ignition Box with boost retard (switch for 1-3 degrees/#), and some sort of MAF box that looks like it plugs in where the factory MAF goes. I have a couple questions and need some help from you guys.
#1 - Why is the MSD box teal and is that an ignition box? I ask because do I need to buy a seperate MSD box and coil to complete the ignition system? I have an Accel ignition box and coil. If the box that came with the kit is the ignition box, then I just need an MSD coil right?
#2 - Do we not use our MAFs with this kit? Should we use the MAF instead of the unit that came with the S-trim? Advantages/disadvantages?
#3 - Should I use the fmu with the kit?
#4 - What kind of hp difference is there (typically) between the 3dgrees/# and 1degree/# of retard?
Old Aug 21, 2003 | 03:29 PM
RealQuick's Avatar
Do any of you other SC'd guys use MAFS?
Old Aug 21, 2003 | 03:32 PM
96TurboTA's Avatar
Is it the MAF translator? It's neededon the 96-97 to stop the MAF codes
Old Aug 21, 2003 | 10:45 PM
BOOST FED 95Z's Avatar
All three Vortech cars I have had, came w/ Crane boxes/ Retard?
Scott
Old Aug 24, 2003 | 08:04 AM
stealth2's Avatar
Find a local shop with Vortech experience and take your car to them. You will not solve your technical issues for free by asking questions on this or other LS1 web sites!
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
