Alternator good, but not charging... (starter related?)
Old Aug 15, 2002 | 06:35 PM
Chuck!'s Avatar
Post Alternator good, but not charging... (starter related?)
I put my engine back in and did the grounds on the back of the heads, then ground the neg. battery to the front of the head. Ran all my wires to the starter (3 O-connectors on the large terminal, 2 on the smaller terminal), but my alternator will not charge my battery! The battery tested fine and the alternator tested fine at autozone and murrays, but there was zero volts (aucutally it measured --.-- on their scanner) going back to the battery to charge it while the car was running.
Anyone have any ideas? Please!
Thanks
Chuck Kulchar
1991 Camaro RS LO3 A4
15.823 @ 85.84 MPH
Project sLO3: the lil big project
Old Aug 15, 2002 | 08:18 PM
92BLKL98's Avatar
I know this sounds kind of stupid but did you hook up the red wire to the back of the alternator BAT lug. Stranger things happen.
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods, removed cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
[This message has been edited by 92BLKL98 (edited August 15, 2002).]
Old Aug 15, 2002 | 09:44 PM
mod313's Avatar
Check the treigger wire in the 2 or 3 wire connector. It must see 12v only when key is in run position to "turn on" the alternator.
Just went thru this myself.
Old Aug 16, 2002 | 01:27 AM
Chuck!'s Avatar
Found my problem. I feel like an idiot admiting this, but the wire that runs from the alt to the battery musta fell down with the other wires so I just attached it to the small stud. Only the purple wire is suppoed to be attached. Runs like a champ now
Thanks for responding guys!
Dec 1, 2016 05:37 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Gtpguy
Jan 26, 2015 04:50 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
