1LE swap??
Old Aug 16, 2003 | 05:55 PM
IROC350's Avatar
1LE swap??
can i swap from rear 1LE calipers to rear regular calipers?? i heard i can and i can't. i heard the rotors were different, not making it possible for me to swap. if this is the case i have to get another 1LE caliper. 1 1LE caliper is the same as 2 regular calipers, so i'll be spending the same amount of $$$. thanks guys, your help is appreciated!
Old Aug 16, 2003 | 08:13 PM
dave89gta's Avatar
The rotors are different sizes, and as far as I know, they CANNOT be interchanged.
Old Aug 17, 2003 | 06:10 AM
87DJP2001's Avatar
If you have the Stock 9-bolt rear it came with 11.655 dia rotors and Aluminum PBR calipers and are Not A 1LE RPO. Why change the Calipers??? Just for the cost???
Old Aug 17, 2003 | 10:31 AM
IROC350's Avatar
so they are not 1LE calipers?? and yes, i do have the stock 9-bolt rear. i'm just weighing my options.
Old Aug 17, 2003 | 10:56 AM
TheGreatJ's Avatar
They aren't 1LE, they're just the late-style (89+) aluminum PBR calipers. Unless it is an actual 1LE car, which is a bit unlikely.
Old Aug 17, 2003 | 01:10 PM
87DJP2001's Avatar
Same rear brakes used on the 1LE cars, 11.655 rotors and PBR calipers. The fronts are the 12" rotors.
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
