TH-350 question
Old Aug 15, 2003 | 03:26 AM
DarthIROC's Avatar
Question TH-350 question
Im putting a built TH-350 behind my 406 instead of the R4 cause I dont need OD, for a trailer queen. It will be with a 3500+ convertor. Prety strong set up
My delima is that i bought the tranny already for the build-up, but I got one that has the MV-4 code I think. I bought a book and it says that its a TCC convertor tranny. 3rd gear only I think. But I have no use or desire for lock-up. Plus all the high end buildup kits in Summit, say non-lockup only.
What Im wondering is, can I just buy a regular convertor, and a normal non-lock up rebuild kit and it will work, do I have to have modifications done to the tranny for it to work with a non-lockup convertor? Or do I just need to scrap this one and get another one?
Old Aug 15, 2003 | 03:45 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i think you should give me your car jeremy... she hates you anyway.
Old Aug 15, 2003 | 09:55 AM
dreamer1q's Avatar
You will need to get a NON lockup case to make it work. Which I personally recommend.
Q
Old Aug 15, 2003 | 11:34 PM
DarthIROC's Avatar
Theres nothing I can do? Because I know you can modify the lock-up R4s to be non lock-up.
Old Aug 16, 2003 | 12:11 AM
OneFlyn95z28's Avatar
ACTUALLY the Lock-up would be nice for extra MPH on the top end.
Either way you can convert that one to non-lock-up.
The easiest way to tell if you have a lock-up unit if there is a electrical plug in on the driver side of the trans. second is the a small smooth section sticking out of the input shaft past the splines.
Good luck!
Old Aug 16, 2003 | 01:24 AM
DarthIROC's Avatar
Good luck!
I already know it is lock-up. The case identification matches, and it has the computer plug. What I need to know is how to get rid of it. I wouldnt think it would be that useful, and a high performance rebuild would cost alot more with lock-up I would imagine.
Old Aug 16, 2003 | 09:00 AM
ok??
The only thing that cost more is the Converter.
Every thing else cost about the same? Only thing that could toss a curve at you is if the input shaft is toast?
every basic part in a TH350 and a TH350C is the same save for the case, input, converter and extra VB for lock-up.
TransGo has a nice HP shift kit for them now also.
I see no reason not to use what you have unless you just do not want lock-up?
As I stated you can convert the one you have at an extra cost to stanard TH350 by changing the pump, input shaft and using a Supirior VB kit.
Also TH350C units usually have more bearings in them using less HP to run them.
In the end it is your choice. I am just offering options to the un-known and solutions to your problem
Old Aug 16, 2003 | 11:56 PM
DarthIROC's Avatar
In all the catalogs Ive looked in Ive never seen a serious race ready rebuild kit, or 3500+ stall equipped for lock-up.
It just seems like it would be more beneficial to get rid of it.
Do you have links to someone who would sell the components, so I can compare prices?
If not does anybod know the actual process for getting rid of it? What has to be done?
Old Aug 17, 2003 | 02:02 AM
frmula1's Avatar
I TOLD YOU, YOU NO TELL ME DAMN RIGHT
Old Aug 17, 2003 | 10:53 AM
Timberwolf's Avatar
What is the benefit of having it non lockup? I know a lot of guys who set their tranny in 4l60e cars to lockup at midway through 3rd gear and WOT...usually they see a couple mph better in trap speed. It would seem a non lockup would just create more heat and a couple hp loss form the "slipping" of the non lockup converter.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Victory Racing
Sep 1, 2002 05:34 PM
