Speed Density ???
Old Aug 12, 2003 | 08:47 PM
shwine617's Avatar
Speed Density ???
How can you identify if you have speed density or mas air flow? did all camaros from 1990 have speed density??
because i see in some pics there is a sensor going into the airbox, I heard this of for speed density??but i don't have one of these. could this affect the car?
thanks
Old Aug 12, 2003 | 09:06 PM
Geezer powered's Avatar
90-93 had speed density.The maf sensor does not go in the air box rather inline between the tb and air box.If your car is maf and you don't have a maf sensor your car would be running extremly sh!tty.It would run really bad.
Old Aug 13, 2003 | 12:54 AM
aklim's Avatar
Pre 90 is MAF. There would be a black colored thing that looks like a soda can with wires coming from it in the path from the TB to the airbox.
Old Aug 13, 2003 | 08:38 AM
shwine617's Avatar
I know what the MAF looks like, but what I am talking about is in the airbox,its smaller,has like one wire going to it, looks like an oxygen sensor, its like right inbetween the air filters and the TB on the driver's side. I think its the air temp sensor, now I don't have one of these, So this can affect the air/fuel mixture i think??
but I have no clue where the wire would be to put one back in.
thanks
Old Aug 13, 2003 | 12:32 PM
Zepher's Avatar
That sounds like the MAT sensor. Many people relocate it from the bottom of the plenum to the airbox so that the ecm reads a colder air temp and is supposed to give you more power.
I did it on my car, but I did so much to it at one time that I didn't get a before and after test.
Old Aug 13, 2003 | 03:06 PM
shwine617's Avatar
If you email me at shwine617@aol.com I can show you a pic of what I am talking about, thanks!
Old Aug 13, 2003 | 07:21 PM
aklim's Avatar
It gives you more power but you would be always be running richer than you should. AFAIK, that sensor should be in the plenum area. According to my diagrams, you should have a 2 wire sensor. One black and one tan. The black is the common ground and the tan is the signal.
Old Aug 13, 2003 | 07:55 PM
bmillington's Avatar
If it's any help, I used! to have a 89 RS 3.8 5spd that had exactly what your talking about. I belive it was a MAT or air temp sensor. And I'm 75% sure it had a mass air flow sensor as well, but not positive. Sorry for not giving you any sold info.
Old Aug 15, 2003 | 08:03 PM
camaroz28racer2's Avatar
The V6 cars it was in the snorkel, the V8's its in the intake manifold itself, thats where you're confused.
Old Aug 16, 2003 | 10:49 AM
shwine617's Avatar
ohh ok, now i see, where is it in the manifold? thanks
Old Aug 16, 2003 | 09:06 PM
Zepher's Avatar
It's in the underside of the plenum (the plenum is the long center piece on top where the runners attach)
Dec 1, 2016 05:37 PM
May 8, 2015 11:30 AM
3TAS4ME
Apr 15, 2015 02:24 PM
Mar 15, 2015 07:01 PM
