Is there a site that figures out correction factors?
Old Jul 26, 2003 | 09:55 PM
REPO's Avatar
Just curious if there is a site that would figure out what mph would equal what 1/4 mile time at 0 elevation.
Isn't there some NHRA site or table out there?
Old Jul 27, 2003 | 12:17 AM
Stephen 87 IROC's Avatar
I have to assume you went to Prince George's track. It's listed as 2300 feet above sea level. What was the temperature, humidity and barometric pressure since those will change the density altitude?
http://www.nhra.com/tech_specs/altitude.html
Use the Stock/Super Stock conversion
Old Jul 31, 2003 | 12:10 AM
Flat_Tire_'s Avatar
Anything out there to convert for 105 degrees F, first time to the strip, and bad 60' times?
Old Jul 31, 2003 | 12:28 AM
AL SS590 M6's Avatar
A fall day in Michigan
Old Jul 31, 2003 | 05:48 AM
SMOKEmUP.com , specifically this one.
Auto Calcs by Bowling & Grippo , specifically this one.
Old Jul 31, 2003 | 07:52 PM
You want a warm track but when the sun is beating down on it, the oils come out of the asphalt and make it slippery. You'll notice traction improves when it gets cloudy.
There's not much you can do with a slippery track. Everyone is fighting the same conditions.
Dec 1, 2016 05:37 PM
Biggiebound
Apr 21, 2015 11:28 PM
sloppytot
Feb 25, 2015 08:30 PM
Deadbolt24
Jan 19, 2015 01:29 PM
smokin25th
Jan 1, 2015 09:06 AM
