Power window problem
Old Jul 11, 2002 | 01:27 PM
joink's Avatar
Post Power window problem
I was able to roll my drivers side window down once, and on the way back up it would stop (approximately, it was random). I had to wait about 5-10 secs before it could start again. I took it in to get fixed and they supposedly replaced the motor.
I get my car back from the dealer, and it's a lot better, but still pauses. I can go up and down about 3 times before it stops. The window travels up and down at the same speed it always has, it never slows down, just quits for a few seconds. Does anyone know what my problem could be? A loose wire on the switch? I have a 2001 and I had 24k miles on the original motor.
Old Jul 11, 2002 | 04:28 PM
NEWBIE T/A's Avatar
Question
Have you tried the passenger side when the driver's side quits ?
The reason I ask is they are on a circuit breaker - if it overheats power is lost for a little while & then restored after a cooldown.
So, if neither one works I'd suspect that the driver's motor is probably tripping the circuit breaker.
If the passenger side still works, then I'd suspect a loose connection or possibly a bad switch - assuming the replaced motor is good.
Some guesses for you to explore ...
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
Old Jul 12, 2002 | 11:06 AM
kaleelna's Avatar
I've had the same problem. The window will go down and kind of pause for a splite second then on the way back up it will Stop completely for 30 seconds. Finaly it the window wouldn't go up or down. I brought it in and the motor had to be replaced. This happened twice, each time the motor was replaced. Now the window support broke in the car and the window rattles if it is not all the way up. The quality on these cars are very questionable. They don't seam to be built to drive everyday. At least not in Michigan. Luckily I've had no problems with my dealer. They fix everything under warrenty. After the warrenty expires I will probably sell the car. I've had too many little things go wrong with it.
Old Jul 12, 2002 | 11:47 AM
Eric @ DMS's Avatar
Same thing happened on the SS...we've already had both side motors replaced...Take it in and have warranty take care of it (if you have it)...
Eric Cuaresma - CamaroZ28.com Sponsor!
President/Co-owner of Dynamic Motorsports, LLC (DMS)
"Leaving the competition behind..."
Website: http://www.dynamicmotorsports.com
Email: eric@dynamicmotorsports.com
- A performance company by performance enthusiasts FOR performance enthusiasts!
WE WORK TOWARDS HELPING YOU, NOT TOWARDS MAKING MONEY!
Old Jul 12, 2002 | 02:58 PM
Camaro ChriSS's Avatar
I don't have an answer for you, and my problem is slightly different (everyone has problems with the windows, don't they?).
My just goes clunk-clunk-clunk as it goes up/down.
Old Jul 17, 2002 | 10:32 PM
ScLeCo's Avatar
A common lament, its the power window motor, 9/10 times. Just be careful if you have after market tint. Ask me why I say this.
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
Dec 1, 2016 05:37 PM
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
MilkyClr69
Jul 29, 2002 10:01 AM
