Tranny cooler lines?
Old Jul 10, 2002 | 06:08 PM
Myrdyn98's Avatar
Question Tranny cooler lines?
Im trying to install a tranny cooler on my car and in not sure which line going into the radiator is the one returning fluid from the radiator to the tranny. I have a feeling its the one on the bottom but im not sure. anyone have any ideas?
98 z28 camaro a4
K&N filter, free air mod, ported maf, bmr strut tower brace, 10.4mm wires, slp loudmouth, carbon fiber air lid, transgo
Best 1/4 ET 12.9 @ 107
Old Jul 10, 2002 | 06:32 PM
White Rhino's Avatar
Its your top line.You should be able to follow it to where you see a squeze clamp.That is the return line.The high pressure line has no clamp.
Old Jul 10, 2002 | 07:10 PM
Myrdyn98's Avatar
now that i have that infomation i wonder where the hell im gunna mount it
98 z28 camaro a4
Old Jul 12, 2002 | 07:43 AM
Myrdyn98's Avatar
Question
Any idea where i can mount a trans cooler on a 98 camaro?
98 z28 camaro a4
Old Jul 12, 2002 | 01:43 PM
NEWBIE T/A's Avatar
Talking
<font face="Verdana, Arial" size="2">Originally posted by Myrdyn98:
</font>
Mine is mounted on the left front of the radiator. Best I can tell, the cooler is hooked in series w/ the one in the radiator so I get double cooling !!
I have not noticed any ill effects on the A/C , so life is good. I believe those quick straps were how it was attached to the radiator.
Good Luck !!
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
Old Jul 12, 2002 | 03:05 PM
I mounted mine on the front of the ac conensor.I pulled the whole air box assembly of the core support.(4 10mm bolts)Removed the plastic shroud that forces air into the radiator under the front of car.Slid the ac condensor off the radiator being real cafeful.Then put up the cooler and shoved the zipties thru the cooler into condensor.I ran the line b/the plastic shroud thing.The lines came thru by the battery.Theres a good right up i think its on installuniversity.com
dylan1303
May 22, 2015 12:24 PM
RedLineRev
Jan 23, 2003 03:51 PM
Javier97Z28
Sep 8, 2002 07:23 AM
chesee48
Aug 22, 2002 08:28 AM
Dragonballz28
Jul 28, 2002 04:45 PM
