Strange fuse found, what is it
Old May 27, 2003 | 08:26 PM
IgorT.455/406's Avatar
Hey guys, been going through my engine bay, removing everything so I can paint it before the motor goes in. SO, I found this little "box" bolted onto the inner fender right next to the coolant overflow tank. When I went to dissconnect the harness, it turns out there is a 20 amp fuse in it, and its blown! What does this fuse do? thanks. It looks like it's a stock thing.
Old May 27, 2003 | 10:59 PM
MasterEvilAce's Avatar
Ah, i know what you're talking about.
But i'm not quite sure. I think it's for the alternator (i think so, anyways)
Old May 28, 2003 | 12:05 AM
But my alternator always worked! I don't know!
Old May 28, 2003 | 09:17 AM
zulater91's Avatar
it is for your fuel pump
Old May 28, 2003 | 12:17 PM
Fuel pump still works with the fuse out! SO wtf!
Old May 28, 2003 | 12:21 PM
zulater91's Avatar
when i take mine out the fuel pump does not work so i am not sure
Old May 28, 2003 | 01:04 PM
Screamin95's Avatar
if its the fuse im thinking of it could be the ecm fuse
Old May 28, 2003 | 01:24 PM
slayer6x6's Avatar
i was also told the same thing, but when i removed it the pump still worked
Old May 28, 2003 | 02:01 PM
It's near the battery, if it matters....
I think that's the one he's talking about.
Old May 28, 2003 | 02:36 PM
It is near the battery. I still have my ECM hooked up, but the car is carburated. I have a relay switch I rigged up to work with the stock fuel pump, works great!
However, not that long ago, something went wrong and I can't keep a fuse in my interior light/speedometer/horn socket. I don't know what went wrong, but something did. SO, could this be related.
Also, can I remove the computer, all that stuff should still work, correct? THanks.
Old May 28, 2003 | 05:51 PM
TheGreatJ's Avatar
The electronic speedo is run through the ECM so if you yank the computer it's gonna quit working.
Also in a lot of GM cars the lighter socket is run off the same circuit as the interior lights....try disconnecting it because sometimes they'll short out and eat fuses.
1996LT1Z28
Jul 20, 2015 02:00 PM
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
