Idle is very high
Old May 26, 2003 | 02:14 AM
Pasky's Avatar
Unhappy Idle is very high
Ok, I replaced my IAC and TPS (its a 3.1 V6 91 camaro). I put it in diagnostic and kept the key on "on" for 30 seconds and unplugged the IAC. I adjusted the idle and without the IAC plugged in it idles at about 550, which is what I want, with the IAC it stays at 1500 =(. I don't understand why after I do this and plug my IAC in it stays at 1500, even after I let the IAC relearn itself. I don't think you can adjust the TPS on these cars and I can't fix my timing until I fix this idle. I had the car checked for vacuum leaks and it has none. Im desperate here, been having this problem for 4 weeks now. Can anyone offer some ideas?
Old May 26, 2003 | 03:19 AM
DarthIROC's Avatar
Why cant you just adjust the idle back down to 550 or wherever you wanted it with the peice plugged in and forget about it?
Old May 26, 2003 | 04:55 AM
Pasky's Avatar
Because my IAC (idle air control) will compensate while it is plugged in. If I lower the idle screw down while my IAC is plugged in, it will only compensate for what I just lowered. Im hoping someone else has experienced this problem and knows what the problem is.
Old May 26, 2003 | 02:54 PM
Pasky's Avatar
Need this problem fixed please, anyone have an idea?
Old May 29, 2003 | 02:32 PM
Pasky's Avatar
bump
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
