60ft times,second gen cars..what times and what setups..??
Old May 25, 2003 | 09:14 PM
80TA's Avatar
I am wondering if some of you can post your 60fts and say what tire,what suspension mods like type of shocks,
shock settings if adjustable,etc...and only interested in automatic cars..I guess also what gears,what stall torque converter..tranny..
Just trying to figure out a good set up to get some great 60fts..no tubbed or 4 link cars either though.
Old May 25, 2003 | 11:22 PM
Erik's Avatar
Classic Tech Moderator
My old setup...
1980 Z28. 270rwhp
Stock suspension - new stock springs front and back, newer shocks.
TH350 3.42 gears, 2500 stall.
235/60 15 BFG Radial T/A's
consistant 1.9 - 2.0 60'
13.6@103 1/4 times.
Old May 26, 2003 | 03:19 AM
ahotrod79's Avatar
My 60 ft times are low to mid 1.7s using et streets and high 1.7s with my sportsman pros.
I am still using the original multi leaf springs and have no problems hooking up (can pull the the front wheels) or having wheel hop.
I have no traction devices other than some heavy duty shocks on the rear (look like a coilover and got them from auto zone) and the sticky tires.
I have a TH350 tranny with 3000 stall converter.
The rear is a 10 bolt posi with 3.73 gears.
Runs low 12s and moves down the highway great.
Old May 26, 2003 | 10:20 AM
cadjock's Avatar
1979 Camaro
CE traction bars
BFG Radial TA's
3.73:1 Posi
383 CID
1.90 average with both 2400 and 300 stall converter
Old May 26, 2003 | 04:58 PM
Capn Pete's Avatar
'81 Z28:
- 383 (roughly ~350HP)
- TH350
- factory stall
- 3.42 posi
- Lakewood trac-bars
- Dunlop GT Qualifiers (street tires)
- car not 100% tuned........
.........best of 2.067 60' time (others of 2.083 / 2.100).
Beyond the 60' mark, the car was falling on its nose because the carb sucked (stock Q-Jet) and the engine was leaning out over 4500 rpm..................yet around home, it would rev out to ~6500?! My best 1/4 time was only 14.214.
I think that if I had the right carb (750 cfm most likely ) and with a little bit of "tweaking", the car probably could have cut sub-2.0 60' times, and probably 12's.
Old May 27, 2003 | 04:09 PM
Z28camaro373's Avatar
1979 Z28:
255/60R15 BFG radial t/a's
factory 3.73 posi rear end
Performer RPM intake
Edlebrock 600 cfm carb
headman shorty headers
40 series flowmasters
2.15 60'
15.20 ET
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 1, 2015 08:26 AM
jdohman
Jul 22, 2002 06:01 PM
