what's a transbrake?
Old Jul 23, 2002 | 11:48 PM
blksgZ28's Avatar
Post what's a transbrake?
exactly as it states, what is it?
Old Jul 24, 2002 | 12:13 AM
zturbo's Avatar
Trans brake engages reverse and first at the same time so you can not move and you load the trany (although it does not load suspension) release trans brake it disengages reverse and gives you a severe shock.
Steven
383 Inches of stroked turbocharged fun.
If one is good shouldnt 2 be great?????
TURBO=TORQUE
TORQUE=FUN
My Car
Old Jul 24, 2002 | 09:02 PM
Stephen 87 IROC's Avatar
Powerglide brakes use first and reverse. All the turbo trannys use first and third no matter who's transbrake you use. I use a Turbo Action transbrake.
A transbrake is a specially designed valve body and an electric solinoid. When the tranny is in first gear and the brake is engaged it directs fluid to the third gear circuit which will lock the tranny in 2 gears at once. When the brake is released all the fluid for third gear is dumped and the car launches forward in first.
A transbrake allows you to bring the engine rpm up to the torque converter's stall speed although you don't always have to bring the rpms up that high if the track is slick. The vehicle brakes can never hold back the car trying to do this. Using a transbrake is like using a manual transmission and doing a high rpm clutch drop. It has about the same effect on the driveline with a huge shock load.
I built up a TH400 with a transbrake. At the same time, I got rid of the 7.5" diff for a 9" and got a 3" x .083" steel driveshaft made with 1350 series u-joints.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Mar 13, 2016 03:37 PM
revtime
Feb 27, 2006 10:43 PM
simple
Jul 21, 2004 05:31 PM
S.R.95Z28
Apr 9, 2003 07:02 PM
