cheap wheels to use with 26 x 10.5 x 15 ET Streets on 4th gen?
Old Jul 23, 2002 | 06:33 AM
JoshGuitar's Avatar
Question cheap wheels to use with 26 x 10.5 x 15 ET Streets on 4th gen?
I wanna try to go with 15" instead of 16", but I'm not sure where to get some cheap wheels to use. 16x8" wheels are easy to find used for a 4th gen, but the only 15x8's I see at sites like tacreationsusa.com are for a 2nd gen, and the backspacing is way off...I don't think they'll work. There's some 3rd gen 15x7's, but they also have the wrong backspacing. Plus I don't think a 15x7 is gonna be wide enough for a 10.5" wide tire. Is my only option for 15's to buy some draglites or something? Or are there some other cheap 15" wheels I can get somewhere? I don't wanna pay the money for draglites at the moment, so am I gonna be stuck getting 16's?
Self esteem is for the conceited.
1994 Trans Am
K&N FIPK, SLP Loudmouth, TBB, !donkeydong
13.968 @ 98.06 MPH
Old Jul 23, 2002 | 07:31 AM
TedH's Avatar
Some of those cheap steel rims that people use on pickup trucks? Maybe Pep Boys or somewhere has those in stock. Hey its not like you will be running them on the street so it may be an option.
Also, you can try a junkyard. They just have to work, not look pretty.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Jul 23, 2002 | 08:34 AM
JoshGuitar's Avatar
how do these look?
http://store.summitracing.com/partdetail.asp?part=5310
$45 a wheel ain't bad, I just don't wanna be spending $150 each or more for some nice draglites (at least at the moment). Is that the measurements I need? (15" dia, 8" wide, 5" backspace, 5 x 4.75" bolt circle). It says it needs 45 degree seat lugnuts...ours are 45 degree, right? Doesn't look like I'll need longer studs with those, will I?
Old Jul 23, 2002 | 05:17 PM
rskrause's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JoshGuitar:
how do these look?
</font>
Would 5" BS be enough? I think they'd stick out too far.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Jul 23, 2002 | 06:20 PM
mongse_1's Avatar
It'd be close...Convo Pros are 8" w/ 5" BS(or close to that) and don't look too bad from the front or the sides. From the back, they stick out, but it's because of the way the back of the car's shaped.
Mar 13, 2016 03:39 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
