98 Digital Odometer Swap In! help??
Old Oct 23, 2007 | 03:53 PM
khojo16's Avatar
Question 98 Digital Odometer Swap In! help??
i just bought a gauge cluster with a digital odometer from a 98 T/A to swap into my 96 Formula...my car currently has an analog odometer. When i pulled out my original gauge cluster to replace it with the 98 cluster, everything went fine with the swap except with the 98 cluster, the TCS light stayed on which i expected since i dont have traction control, the rpm gauge read about 800rpms too high, and the fuel gauge didnt move (read my tank as empty when it was full)...any idea on how to fix this problem as i would like to swap the digital back into my car soon...
Old Oct 23, 2007 | 05:01 PM
camarozz95's Avatar
I'm not positive, but I don't think you can make it work the tach is always going to be off, and I'm not sure about the gas gauge. I think you needed a 97 digital cluster for it to work right.
Old Oct 23, 2007 | 07:08 PM
RE AND CHERYL's Avatar
LS1 gauges will not work in LT1 vehicles. The tach won't work right because the LT1 PCM puts out twice as many pulses as a LS1 PCM and the fuel gauge won't work because the the resistance range on the LT1 fuel gauge is 0-90 ohms and it's 70-240 ohms on a LS1 fuel gauge.
Re'
Old Oct 23, 2007 | 08:45 PM
khojo16's Avatar
o wow...good info...wish i had found that out before i bought it lol...so i will be fine with buying a 97 digital cluster and swapping it in tho right?
Old Oct 24, 2007 | 03:48 PM
Yes
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
