remove wax/sap?
Old 03-14-2013, 04:13 PM
ablkbrd's Avatar
remove wax/sap?
need help removing sap or wax... or something. this stuff is like glue, it just will not come off. i can scratch it off with my finger nail but its all over the car. help please!
ablkbrd is offline
Old 03-14-2013, 05:16 PM
jloshotz's Avatar
remove wax/sap?
There is a solvent actually called bug and tar remover, I know auto zone carries it. Google "bug and tar remover" and you'll find it
jloshotz is offline
Old 03-14-2013, 06:33 PM
moparman's Avatar
Re: remove wax/sap?
A clay bar might get it. Dawn dish washing liquid and a mesh type sponge might help.
moparman is offline
Old 03-15-2013, 12:05 PM
ablkbrd's Avatar
Re: remove wax/sap?
thanks guys, bug and tar remover a no go... clay bar is next. then rubbing compound... this sucks. dont want to kill the paint.
ablkbrd is offline
Old 03-17-2013, 03:43 PM
Randy Bilyea's Avatar
Re: remove wax/sap?
Tree sap: Ice it down and peel it off with your nail. Got to get it really cold though. Not a problem HERE right now...
Randy Bilyea is offline
Old 03-17-2013, 07:50 PM
96 Z 28's Avatar
Re: remove wax/sap?
I've heard Goof-Off or Purell Hand Sanitizer.
96 Z 28 is offline
Old 03-18-2013, 04:01 PM
parkers Z28's Avatar
Re: remove wax/sap?
The clay bar should do it .... be careful with the rubbing compound !!!!!!!!!! look at what size
the grit is in the rubbing compound ... try it out in a small spot to make sure it does not eat the paint off I would try several things before I would use a rubbing compound !!!
There is a big difference between rubbing compound and a polishing compound
parkers Z28 is offline
Old 03-19-2013, 11:05 AM
30th97z's Avatar
Re: remove wax/sap?
Meguiar's Clay Bar!
30th97z is offline
Old 03-21-2013, 03:42 PM
ablkbrd's Avatar
Re: remove wax/sap?
weather has been crappy... it does peel off when its super cold out.. but spring will be here by the time i use my thumb naul to get it all. havent used the clay bar yet but hopeful
ablkbrd is offline
Old 04-02-2013, 12:06 PM
Scrub88's Avatar
Re: remove wax/sap?
Had this same problem while parking my daily truck under pine trees at work ..covered in this goo ..I used denatured alcohol it removed it pretty well and I used wd40 as well it didn't seem to have any effect on the paint . Might try that in a small spot to test .
Scrub88 is offline
Old 07-20-2013, 07:45 AM
websdown's Avatar
Re: remove wax/sap?
I have used alcohol and it worked on black with clear coat no bad effects or dulling and have used clay bar on small pin head type sap spots from Black Walnut trees if baked on. Other wise a lot of regular tree saps come off with just water/Except PINE SAP. But I would try the Alcohol before I would use rubbing compound as long as you have clear coat on top. GOOD LUCK.
websdown is offline
greenzee28
09-25-2015 04:29 PM
Jake Bialke
09-24-2015 11:31 AM
wbspoon
09-19-2015 08:12 AM
NewsBot
09-14-2015 09:20 AM
RX Speed Works
09-11-2015 03:31 PM
Quick Reply: remove wax/sap?
