throttle position sensor adjustment
Old 10-07-2011, 04:18 PM
  #16
Rij1's Avatar
Re: throttle position sensor adjustment
I did the black and grey wire,
I'll do that rite now
Rij1 is offline
Old 10-07-2011, 04:22 PM
  #17
Rij1's Avatar
4.47 closed throttle .575 wot key on engine off between blue and black
Rij1 is offline
Old 10-07-2011, 04:24 PM
  #18
You measured something wrong. The gray wire supplies the 5.0V reference voltage from the PCM. I assume you measured between the gray wire and the black wire when you measured 5V. If you have 5V on the gray wire, there is no way you can have a signal voltage that exceeds 5V.
Injuneer is offline
Old 10-07-2011, 04:26 PM
  #19
Rij1's Avatar
Sorry, i corrected my post
Rij1 is offline
Old 10-07-2011, 04:29 PM
  #20
Rij1's Avatar
4.47v wot .575v closed throttle key on engine off between blue and black
Rij1 is offline
Old 10-12-2011, 12:05 AM
  #21
dennis5374's Avatar
On my 93 I measured the blue wire with a multimeter.
dennis5374 is offline
Old 10-12-2011, 05:22 AM
  #22
That's OK. There is no need to set the TPS closed throttle voltage at any fixed number. As long as the closed throttle voltage is between 0.20-0.90V the PCM will baseline the voltage as the 0% throttle position, and then prorate up to that voltage plus four to establish the throttle open %.
Most factory, unmolested sensors read about 0.65-0.67V. Some people claim they get better results at a very specific number, like 0.50V but I've never seen any evidnece of that being true. Not in the LT1. That was true with the 3rd Gens. I've reviewed 100's of data log for people and the numbers can vary all over the place. If the values fall out of the acceptable range, you will get codes.
Injuneer is offline
Old 10-12-2011, 12:43 PM
  #23
Rij1's Avatar
Rij1 is offline
HectorM52
07-30-2017 11:46 AM
eazyZ
03-01-2015 07:12 AM
dirtybird81
10
01-06-2015 09:31 PM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: throttle position sensor adjustment
